The client and server programs use certain support functions, for example to display the value of returned flags. As they are either not specific to the GSS-API or else are not terribly important, they are not covered here. They may be found in Ancillary Functions. Two of them, however, send_token() and recv_token(), are significant enough that they are listed separately in send_token() and recv_token().
