ONC+ Developer's Guide
Print Message Program With Remote Version
Example D–7 printmesg.c
/* printmsg.c: print a message on the console */
#include <stdio.h>
main(argc, argv)
 	int argc;
 	char *argv[];
	char *message;
	if (argc != 2) {
		fprintf(stderr, "usage: %s <message>\n", argv[0]);
		exit(1);
	message = argv[1];
	if( !printmessage(message) ) {
		fprintf(stderr, "%s: couldn't print your message\n",
		        argv[0]);
		exit(1);
	printf("Message Delivered!\n");
	exit(0);
/* Print a message to the console. */
 * Return a boolean indicating whether the message was actually
 * printed.
printmessage(msg)
	char *msg;
	FILE *f;
	if = fopen("/dev/console","w");
		if (f == (FILE *)NULL)
			return (0);
	fprintf(f,"%sen”, msg);
	fclose(f);
	return (1);
Example D–8 Remote Version of printmesg.c
/*  * rprintmsg.c: remote version of "printmsg.c”  */
#include <stdio.h>
#include <rpc/rpc.h> /* always needed */
#include "msg.h”     /* msg.h generated by rpcgen */
main(argc, argv)
	int argc;
	char *argv[];
	CLIENT *cl;
	int *result;
	char *server;
	char *message;
	extern int sys_nerr;
	extern char *sys_errlist[];
	if (argc != 3) {
		fprintf(stderr,"usage: %s host messagen", argv[0]);
		exit(1);
	 * Save values of command line arguments
	server = argv[1];
	message = argv[2];
 * Create client"handle” used for calling
 * MESSAGEPROG on the server
 * designated on the command line.
	cl = clnt_create(server, MESSAGEPROG, PRINTMESSAGEVERS,
	                 "visible");
	if (cl == (CLIENT *)NULL) {
		 * Couldn't establish connection with server.
		 * Print error message and die.
		clnt_pcreateerror(server);
		exit(1);
	/* Call the remote procedure "printmessage" on the server */
	result = printmessage_1(&message, cl);
	if (result == (int *)NULL) {
	 * An error occurred while calling the server.
		clnt_perror(cl, server);
		exit(1);
	/* Okay, we successfully called the remote procedure. */
	if (*result == 0) {
		 * Server was unable to print our message.
		fprintf(stderr,"%s"
/* The message got printed on the server's console */
	printf("Message delivered to %s!\n", server);
	exit(0);
Example D–9 rpcgen Program: msg.x
/* msg.x: Remote message printing protocol */
program MESSAGEPROG {
 	version MESSAGEVERS {
 		int PRINTMESSAGE(string) = 1;
 	} = 1;
} = 0x20000001;
Example D–10 mesg_proc.c
 * msg_proc.c: implementation of the remote
 * procedure "printmessage"
#include <stdio.h>
 * Remote version of "printmessage"
/*ARGSUSED1*/
int printmessage_1(msg, req)
	char **msg;
	struct svc_req *req;
	static int result; /* must be static! */
	FILE *f;
	f = fopen("/dev/console", "w");
	if (f == (FILE *)NULL) {
		result = 0;
		return (&result);
	fprintf(f, "%sen", *msg);
 	fclose(f);
 	result = 1;
 	return (&result);
