sacadm is the administrative command for the upper level of the SAF hierarchy, that is, for port monitor administration. See the sacadm(1M) man page. Under the SAF, port monitors are administered by using the sacadm command to make changes in the SAC's administrative file. sacadm performs the following functions:
Prints requested port monitor information from the SAC administrative file
Adds or removes a port monitor
Enables or disables a port monitor
Starts or stops a port monitor
Installs or replaces a per-system configuration script
Installs or replaces a per-port monitor configuration script
