Relative to its current directory, the key files listed in the following table exist for a port monitor.
Table F–3 Key Port Monitor Files
File |
Description |
The port monitor's configuration script. The port monitor configuration script is run by the SAC. The SAC is started by init() as a result of an entry in /etc/inittab that calls the SAC. |
The port monitor's administrative file. This file contains information about the ports and services for which the port monitor is responsible. |
The FIFO through which the port monitor receives messages from the SAC. |
The per-service configuration script for the service with the tag svctag. |
The FIFO through which the port monitor sends messages to the SAC. |
