When a procedure has been called through broadcast RPC and cannot provide a useful response, the server should send no reply to the client, thus reducing network traffic. To prevent the server from replying, a remote procedure can return NULL as its result. The server code generated by rpcgen detects this return and sends no reply.
The following code example is a procedure that replies only if it reaches an NFS server.
void * reply_if_nfsserver() { char notnull; /*only here so we can *use its address */ if( access( "/etc/dfs/sharetab", F_OK ) < 0 ) { /* prevent RPC from replying */ return( (void *) NULL ); } /* assign notnull a non-null value * then RPC sends a reply */ return( (void *) ¬null ); }
A procedure must return a non-NULL pointer when it is appropriate for RPC library routines to send a reply.
In the example, if the procedure reply_if_nfsserver() is defined to return nonvoid values, the return value ¬null should point to a static variable.
