ONC+ Developer's Guide
Server Caching
svc_dg_enablecache() initiates service caching for datagram transports. Caching should be used only in cases where a server procedure is a “once only” kind of operation. Executing a cached server procedure multiple times yields different results.
svc_dg_enablecache(xprt, cache_size)
    SVCXPRT *xprt;
    unsigned int cache_size;
This function allocates a duplicate request cache for the service endpoint xprt, large enough to hold cache_size entries. A duplicate request cache is needed if the service contains procedures with varying results. After caching is enabled, it cannot be disabled.
