The following example is a short XDR data description of a file data structure that might be used to transfer files from one machine to another.
const MAXUSERNAME = 32;/* max length of a user name */ const MAXFILELEN = 65535; /* max length of a file */ const MAXNAMELEN = 255; /* max length of a file name */ /* Types of files: */ enum filekind { TEXT = 0, /* ascii data */ DATA = 1, /* raw data */ EXEC = 2 /* executable */ }; /* File information, per kind of file: */ union filetype switch (filekind kind) { case TEXT: void; /* no extra information */ case DATA: string creator<MAXNAMELEN>; /* data creator */ case EXEC: string interpreter<MAXNAMELEN>; /*proginterptr*/ }; /* A complete file: */ struct file { string filename<MAXNAMELEN>; /* name of file */ filetype type; /* info about file */ string owner<MAXUSERNAME>; /* owner of file */ opaque data<MAXFILELEN>; /* file data */ };
Suppose now that a user named linda wants to store her LISP program sillyprog that contains just the data "quit." Her file would be encoded as listed in the following table.
Table C–1 XDR Data Description Example
Offset |
Hex Bytes |
ASCII |
Description |
0 |
00 00 00 09 |
Length of file name = 9 |
4 |
73 69 6c 6c |
sill |
File name characters |
8 |
79 70 72 6f |
ypro |
More characters |
12 |
67 00 00 00 |
g |
3 zero-bytes of fill |
16 |
00 00 00 02 |
Filekind is EXEC = 2 |
20 |
00 00 00 04 |
Length of interpreter = 4 |
24 |
6c 69 73 70 |
lisp |
Interpreter characters |
28 |
00 00 00 04 |
Length of owner = 4 |
32 |
6a 6f 68 6e |
linda |
Owner characters |
36 |
00 00 00 06 |
Length of file data = 6 |
40 |
28 71 75 69 |
(qu |
File data bytes |
44 |
74 29 00 00 |
t) |
2 zero-bytes of fill |
