This appendix contains the XDR Protocol Language Specification. It covers the following topics:
External data representation (XDR) is a standard for the description and encoding of data. The XDR protocol is useful for transferring data between different computer architectures and has been used to communicate data between very diverse machines. XDR fits into the ISO reference model's presentation layer (layer 6) and is roughly analogous in purpose to X.409, ISO Abstract Syntax Notation. The major difference between the two is that XDR uses implicit typing, while X.409 uses explicit typing.
XDR uses a language to describe data formats and can only be used to describe data. It is not a programming language. This language enables you to describe intricate data formats in a concise manner. The XDR language is similar to the C language. Protocols such as RPC and NFS use XDR to describe the format of their data.
The XDR standard assumes that bytes, or octets, are portable and that a byte is defined to be 8 bits of data.
This appendix uses graphic box notation for illustration and comparison. In most illustrations, each box depicts a byte. The representation of all items requires a multiple of 4 bytes (or 32 bits) of data. The bytes are numbered 0 through n -1. The bytes are read or written to some byte stream such that byte m always precedes byte m+1. The n bytes are followed by enough (0 to 3) residual zero bytes, r, to make the total byte count a multiple of four. Ellipses (...) between boxes show zero or more additional bytes where required, as shown in the following illustration.
Choosing the XDR block size requires a tradeoff. Choosing a small size such as 2 makes the encoded data small, but causes alignment problems for machines that are not aligned on these boundaries. A large size such as 8 means the data is aligned on virtually every machine, but causes the encoded data to grow too large. Four was chosen as a compromise. Four is big enough to support most architectures efficiently.
This basic block size of 4 does not mean that the computers cannot utilize standard XDR, just that they do so at a greater overhead per data item than 4-byte (32-bit) architectures. Four is also small enough to keep the encoded data restricted to a reasonable size.
The same data should encode into an equivalent result on all machines so that encoded data can be compared or checksummed. So, variable-length data must be padded with trailing zeros.
Each of the sections that follow:
Describes a data type defined in the XDR standard
Shows how that data type is declared in the language
Includes a graphic illustration of the encoding
For each data type in the language a general paradigm declaration is shown. Note that angle brackets (< and >) denote variable-length sequences of data and square brackets ([and]) denote fixed-length sequences of data. n, m, and r denote integers. For the full language specification, refer to XDR Language Specification.
Some data types include specific examples. A more extensive example is given in the section XDR Data Description.
An XDR signed integer is a 32-bit datum that encodes an integer in the range [-2147483648,2147483647]. The integer is represented in two's complement notation; the most and least significant bytes are 0 and 3, respectively.
Integers are declared:
int identifier;
An XDR unsigned integer is a 32-bit datum that encodes a nonnegative integer in the range [0, 4294967295]. The integer is represented by an unsigned binary number that has most- and least-significant bytes of 0 and 3 respectively.
An unsigned integer is declared as follows.
unsigned int identifier;
Enumerations have the same representation as signed integers and are handy for describing subsets of the integers. The encoding for enumerations is the same as shown in Signed Integer Encoding.
Enumerated data is declared as follows.
enum {name-identifier = constant, ... } identifier;
For example, an enumerated type could represent the three colors red, yellow, and blue as follows.
enum {RED = 2, YELLOW = 3, BLUE = 5} colors;
Do not assign to an enum
an integer that has not been assigned
in the enum
declaration.
Booleans are important enough and occur frequently enough to warrant their own explicit type in the standard. Booleans are integers of value 0 or 1. The encoding for Booleans is the same as show in Signed Integer Encoding.
Booleans are declared as follows.
bool identifier;
This is equivalent to:
enum {FALSE = 0, TRUE = 1} identifier;
The standard defines 64–bit (8-byte) numbers called hyper
int
and unsigned
hyper
int
with representations that are the obvious extensions of integer
and unsigned integer,
defined previously. They
are represented in two's complement notation; the most-significant and least-significant
bytes are 0 and 7, respectively.
Hyper integers are declared as follows.
hyper int identifier; unsigned hyper int identifier;
The standard defines the floating-point data type float
(32 bits
or 4 bytes). The encoding used is the IEEE standard for normalized single-precision
floating-point numbers [1]. The following three fields describe the single-precision
floating-point number:
S: The sign of the number. Values 0 and 1 represent positive and negative respectively. One bit.
E: The exponent of the number, base 2. Eight bits are in this field. The exponent is biased by 127.
F: The fractional part of the number's mantissa, base 2. Twenty-three bits are in this field.
Therefore, the floating-point number is described by.
(-1)**S * 2**(E-Bias) * 1.F
Single-precision floating-point data is declared as follows.
float identifier;
Double-precision floating-point data is declared as follows.
double identifier;
Just as the most and least significant bytes of an integer are 0 and 3, the most-significant and least-significant bits of a double-precision floating-point number are 0 and 63. The beginning bit, and most significant bit, offsets of S, E, and F are 0, 1, and 12 respectively.
These offsets refer to the logical positions of the bits, not to their physical locations, which vary from medium to medium.
Consult the IEEE specifications about the encoding for signed zero, signed infinity (overflow), and de-normalized numbers (underflow) [1]. According to IEEE specifications, the NaN (not a number) is system dependent and should not be used externally.
The standard defines the encoding for the quadruple-precision
floating-point data type quadruple
(128 bits or 16 bytes). The
encoding used is the IEEE standard for normalized quadruple-precision floating-point
numbers [1]. The standard encodes the following three fields, which describe
the quadruple-precision floating-point number.
E: The exponent of the number, base 2. Fifteen bits are in this field. The exponent is biased by 16383.
F: The fractional part of the number's mantissa, base 2. One hundred eleven bits are in this field.
Therefore, the floating-point number is described by:
quadruple identifier;
Just as the most-significant and least-significant bytes of an integer are 0 and 3, the most-significant and least-significant bits of a quadruple-precision floating- point number are 0 and 127. The beginning bit, and most-significant bit, offsets of S, E, and F are 0, 1, and 16 respectively. These offsets refer to the logical positions of the bits, not to their physical locations, which vary from medium to medium.
At times, fixed-length uninterpreted
data needs to be passed among machines. This data is called opaque
Opaque data is declared as follows.
opaque identifier[n];
In this declaration, the constant n is the static number of bytes necessary to contain the opaque data. The n bytes are followed by enough (0 to 3) residual zero bytes r to make the total byte count of the opaque object a multiple of four.
The standard also provides for variable-length counted opaque data. Such data is defined as a sequence of n (numbered 0 through n-1) arbitrary bytes to be the number n encoded as an unsigned integer, as described subsequently, and followed by the n bytes of the sequence.
Byte b of the sequence always precedes byte b+1 of the sequence, and byte 0 of the sequence always follows the sequence's length. The n bytes are followed by enough (0 to 3) residual zero bytes, r, to make the total byte count a multiple of four.
Variable-length opaque data is declared in the following way.
opaque identifier<m>;
or
opaque identifier<>;;
The constant m denotes an upper bound of the number of bytes that the sequence can contain. If m is not specified, as in the second declaration, it is assumed to be (2**32) - 1, the maximum length. For example, a filing protocol might state that the maximum data transfer size is 8192 bytes, as follows.
opaque filedata<8192>;
Do not encode a length greater than the maximum described in the specification.
The standard defines a string of n (numbered 0 through n-1) ASCII bytes to be the number n encoded as an unsigned integer, as described previously, and followed by the n bytes of the string. Byte b of the string always precedes byte b+1 of the string, and byte 0 of the string always follows the string's length. The n bytes are followed by enough (0 to 3) residual zero bytes r to make the total byte count a multiple of four.
Counted byte strings are declared as follows.
string object<m>;
or
string object<>;
The constant m denotes an upper bound of the number of bytes that a string can contain. If m is not specified, as in the second declaration, it is assumed to be (2**32) - 1, the maximum length. The constant m would normally be found in a protocol specification. For example, a filing protocol might state that a file name can be no longer than 255 bytes, as follows.
string filename<255>;
Fixed-length arrays of elements numbered 0 through n-1 are encoded by individually encoding the elements of the array
in their natural order, 0 through n-1.
Each element's size is a multiple of 4 bytes. Though all elements are of the
same type, the elements might have different sizes. For example, in a fixed-length
array of strings, all elements are of type string
, yet each element
varies in its length.
Declarations for fixed-length arrays of homogenous elements are in the following form.
type-name identifier[n];
Counted arrays enable variable-length arrays to be encoded as homogeneous elements. The element count n, an unsigned integer, is followed by each array element, starting with element 0 and progressing through element n-1.
The declaration for variable-length arrays follows this form.
type-name identifier<m>;
or
type-name identifier<>;
The constant m specifies the maximum acceptable element count of an array. If m is not specified, it is assumed to be (2**32) - 1.
The components of the structure are encoded in the order of their declaration in the structure. Each component's size is a multiple of 4 bytes, though the components might be different sizes.
Structures are declared as follows.
struct { component-declaration-A; component-declaration-B; ... } identifier;
A discriminated union is
a type composed of a discriminant followed by a type selected from a set of
prearranged types according to the value of the discriminant. The type of
discriminant is either int
, unsigned int
, or an
enumerated type, such as bool
. The component types are called “arms”
of the union, and are preceded by the value of the discriminant that implies
their encoding.
Discriminated unions are declared as follows.
union switch (discriminant-declaration) { case discriminant-value-A: arm-declaration-A; case discriminant-value-B: arm-declaration-B; ... default: default-declaration; } identifier;
Each case keyword is followed by a legal value of the discriminant. The default arm is optional. If the arm is not specified, then a valid encoding of the union cannot take on unspecified discriminant values. The size of the implied arm is always a multiple of 4 bytes.
The discriminated union is encoded as its discriminant followed by the encoding of the implied arm.
An XDR void
is a 0-byte quantity. Voids are useful for describing
operations that take no data as input or no data as output. They are also
useful in unions, in which some arms might contain data and others do not.
The declaration is simply as follows.
void;
const
is used to define a symbolic name for a constant. It does not
declare any data. The symbolic constant can be used anywhere a regular constant
can be used.
The following example defines a symbolic constant DOZEN, equal to 12.
const DOZEN = 12;
The declaration of a constant follows this form.
const name-identifier = n;
Typedef
does not declare any data either, but serves to
define new identifiers for declaring data. The syntax is:
typedef declaration;
The new type name is actually the variable name in the declaration part
of the typedef
. The following example defines a new type called eggbox using an existing type called egg and
the symbolic constant DOZEN.
typedef egg eggbox[DOZEN];
Variables declared using the new type name have the same type as the
new type name would have in the typedef
, if it were considered
a variable. For example, the following two declarations are equivalent in
declaring the variable fresheggs:
eggbox fresheggs; egg fresheggs[DOZEN];
When a typedef
involves a struct
, enum
, or union
definition, you can use another (preferred)
syntax to define the same type. In general, a typedef
of the
following form:
typedef <<struct, union, or enum definition>> identifier;
can be converted to the alternative form by removing the typedef
part and placing the identifier after the struct
, enum
, or union
keyword instead of at the end. For example,
here are the two ways to define the type bool
typedef enum {/* using typedef */ FALSE = 0, TRUE = 1 } bool; enum bool {/* preferred alternative */ FALSE = 0, TRUE = 1 };
This syntax is preferred because you do not have to go to the end of a declaration to learn the name of the new type.
The optional-data union occurs so frequently that it is given a special syntax of its own for declaring it. It is declared as follows.
type-name *identifier;
This syntax is equivalent to the following union:
union switch (bool opted) { case TRUE: type-name element; case FALSE: void; } identifier;
The optional-data syntax is also equivalent to the following variable-length array declaration, because the Boolean opted can be interpreted as the length of the array.
type-name identifier<1>;
Optional data is useful for describing recursive data-structures, such as linked lists and trees.
This section contains the XDR language specification.
This specification uses a modified Backus-Naur Form notation for describing the XDR language. Here is a brief description of the notation:
The characters |, (, ), [, ], and * are special.
Terminal symbols are strings of any characters embedded in quotes (").
Nonterminal symbols are strings of nonspecial italic characters.
Alternative items are separated by a vertical bar (|).
Optional items are enclosed in brackets.
Items are grouped by enclosing them in parentheses.
A * following an item means 0 or more occurrences of the item.
For example, consider the following pattern:
"a " "very" (", " " very")* [" cold " "and"] " rainy " ("day" | "night")
An infinite number of strings match this pattern. A few of them are:
a very rainy day a very, very rainy day a very cold and rainy day a very, very, very cold and rainy night
The following conventions are used in the specification.
White space serves to separate items and is otherwise ignored.
An identifier is a letter followed by an optional sequence of letters, digits, or underbars (_). The case of identifiers is not ignored.
A constant is a sequence of one or more decimal digits, optionally preceded by a minus sign (-), as seen in the following code example.
Syntax Information declaration: type-specifier identifier | type-specifier identifier "[" value "]" | type-specifier identifier "<" [ value ] ">" | "opaque" identifier "[" value "]" | "opaque" identifier "<" [ value ] ">" | "string" identifier "<" [ value ] ">" | type-specifier "*" identifier | "void" value: constant | identifier type-specifier: [ "unsigned" ] "int" | [ "unsigned" ] "hyper" | "float" | "double" | "quadruple" | "bool" | enum-type-spec | struct-type-spec | union-type-spec | identifier enum-type-spec: "enum" enum-body enum-body: "{" ( identifier "=" value ) ( "," identifier "=" value )* "}" struct-type-spec: "struct" struct-body struct-body: "{" ( declaration ";" ) ( declaration ";" )* "}" union-type-spec: "union" union-body union-body: "switch" "(" declaration ")" "{" ( "case" value ":" declaration ";" ) ( "case" value ":" declaration ";" )* [ "default" ":" declaration ";" ] "}" constant-def: "const" identifier "=" constant ";" type-def: "typedef" declaration ";" | "enum" identifier enum-body ";" | "struct" identifier struct-body ";" | "union" identifier union-body ";" definition: type-def | constant-def specification: definition *
The following are keywords and cannot be used as identifiers:
Only unsigned constants can be used
as size specifications for arrays. If an identifier is used, it must have
been declared previously as an unsigned constant in a const
definition.
Constant and type identifiers within the scope of a specification are in the same namespace and must be declared uniquely within this scope.
Similarly, variable names must be unique within the scope of struct
and union
declarations. Nested struct
and union
declarations create new scopes.
The discriminant of a union
must be of a type that evaluates
to an integer. That is, it must be an int
, an unsigned
int,
a bool
, an enum
type, or any typedef
that evaluates to one of these. Also, the case
values must be legal discriminant values. Finally, a case
value cannot be specified more than once within the scope of a union
declaration.
The following example is a short XDR data description of a file data structure that might be used to transfer files from one machine to another.
const MAXUSERNAME = 32;/* max length of a user name */ const MAXFILELEN = 65535; /* max length of a file */ const MAXNAMELEN = 255; /* max length of a file name */ /* Types of files: */ enum filekind { TEXT = 0, /* ascii data */ DATA = 1, /* raw data */ EXEC = 2 /* executable */ }; /* File information, per kind of file: */ union filetype switch (filekind kind) { case TEXT: void; /* no extra information */ case DATA: string creator<MAXNAMELEN>; /* data creator */ case EXEC: string interpreter<MAXNAMELEN>; /*proginterptr*/ }; /* A complete file: */ struct file { string filename<MAXNAMELEN>; /* name of file */ filetype type; /* info about file */ string owner<MAXUSERNAME>; /* owner of file */ opaque data<MAXFILELEN>; /* file data */ };
Suppose now that a user named linda wants to store her LISP program sillyprog that contains just the data "quit." Her file would be encoded as listed in the following table.
Table C–1 XDR Data Description Example
Offset |
Hex Bytes |
ASCII |
Description |
0 |
00 00 00 09 |
Length of file name = 9 |
4 |
73 69 6c 6c |
sill |
File name characters |
8 |
79 70 72 6f |
ypro |
More characters |
12 |
67 00 00 00 |
g |
3 zero-bytes of fill |
16 |
00 00 00 02 |
Filekind is EXEC = 2 |
20 |
00 00 00 04 |
Length of interpreter = 4 |
24 |
6c 69 73 70 |
lisp |
Interpreter characters |
28 |
00 00 00 04 |
Length of owner = 4 |
32 |
6a 6f 68 6e |
linda |
Owner characters |
36 |
00 00 00 06 |
Length of file data = 6 |
40 |
28 71 75 69 |
(qu |
File data bytes |
44 |
74 29 00 00 |
t) |
2 zero-bytes of fill |
The RPC language is an extension of the XDR language. The sole extension is the addition of the program and version types.
For a description of the RPC extensions to the XDR language, see Appendix B, RPC Protocol and Language Specification.
