SPARC Assembly Language Reference Manual
2.3 Lexical Features
This section describes the lexical features of the assembler syntax.
2.3.1 Case Distinction
Uppercase and lowercase letters are distinct everywhere except in the names of special symbols. Special symbol names have no case distinction.
2.3.2 Comments
A comment is preceded by an exclamation mark character (!); the exclamation mark character and all following characters up to the end of the line are ignored. C language-style comments (``/*…*/'') are also permitted and may span multiple lines.
2.3.3 Labels
A label is either a symbol or a single decimal digit n (0…9). A label is immediately followed by a colon ( : ).
Numeric labels may be defined repeatedly in an assembly file; normal symbolic labels may be defined only once.
A numeric label n is referenced after its definition (backward reference) as nb, and before its definition (forward reference) as nf.
2.3.4 Numbers
Decimal, hexadecimal, and octal numeric constants are recognized and are written as in the C language. However, integer suffixes (such as L) are not recognized.
For floating-point pseudo-operations, floating-point constants are written with 0r or 0R (where r or R means REAL) followed by a string acceptable to atof(3); that is, an optional sign followed by a non-empty string of digits with optional decimal point and optional exponent.
The special names 0rnan and 0rinf represent the special floating-point values Not-A-Number (NaN) and INFinity. Negative Not-A-Number and Negative INFinity are specified as 0r-nan and 0r-inf.
Note –
The names of these floating-point constants begin with the digit zero, not the letter “O.”
2.3.5 Strings
A string is a sequence of characters quoted with either double-quote mark (") or single-quote mark (') characters. The sequence must not include a newline character. When used in an expression, the numeric value of a string is the numeric value of the ASCII representation of its first character.
The suggested style is to use single quote mark characters for the ASCII value of a single character, and double quote mark characters for quoted-string operands such as used by pseudo-ops. An example of assembly code in the suggested style is:
add %g1,'a'-'A',%g1 ! g1 + ('a' - 'A') --> g1
The escape codes described in Table 2–1, derived from ANSI C, are recognized in strings.
Table 2–1
Escape Code
Description
\a
Alert
\b
Backspace
\f
Form feed
\n
Newline (line feed)
\r
Carriage return
\t
Horizontal tab
\v
Vertical tab
\nnn
Octal value nnn
\xnn...
Hexadecimal value nn...
2.3.6 Symbol Names
The syntax for a symbol name is:
{ letter | _ | $ | . }   { letter | _ | $ | . | digit }*
In the above syntax:
2.3.7 Special Symbols - Registers
Special symbol names begin with a percentage sign (%) to avoid conflict with user symbols. Table 2–2 lists these special symbol names.
Table 2–2
Symbol Object
Name
Comment
General-purpose registers
%r0 … %r31
General-purpose global registers
%g0 … %g7
Same as %r0 … %r7
General-purpose out registers
%o0 … %o7
Same as %r8 … %r15
General-purpose local registers
%l0 … %l7
Same as %r16 … %r23
General-purpose in registers
%i0 … %i7
Same as %r24 … %r31
Stack-pointer register
%sp
(%sp = %o6 = %r14)
Frame-pointer register
%fp
(%fp = %i6 = %r30)
Floating-point registers
%f0 … %f31
Floating-point status register
%fsr
Front of floating-point queue
%fq
Coprocessor registers
%c0 … %c31
Coprocessor status register
%csr
Coprocessor queue
%cq
Program status register
%psr
Trap vector base address register
%tbr
Window invalid mask
%wim
Y register
%y
Unary operators
%lo
Extracts least significant 10 bits
%hi
Extracts most significant 22 bits
%r_disp32
Used only in Sun compiler-generated code.
%r_plt32
Ancillary state registers
%asr1 … %asr31
There is no case distinction in special symbols; for example,
%PSR
is equivalent to
%psr
The suggested style is to use lowercase letters.
The lack of case distinction allows for the use of non-recursive preprocessor substitutions, for example:
#define psr %PSR
The special symbols %hi and %lo are true unary operators which can be used in any expression and, as other unary operators, have higher precedence than binary operations. For example:
%hi a+b  =  (%hi a)+b
%lo a+b  =  (%lo a)+b
To avoid ambiguity, enclose operands of the %hi or %lo operators in parentheses. For example:
%hi(a) + b
2.3.8 Operators and Expressions
The operators described in Table 2–3 are recognized in constant expressions.
Table 2–3
Binary
Operators
Unary
Operators
Integer addition
(No effect)
Integer subtraction
2's Complement
Integer multiplication
1's Complement
Integer division
%lo(address)
Extract least significant 10 bits as computed by: (address & 0x3ff)
Modulo
%hi(address)
Extract most significant 22 bits as computed by: (address >>10)
Exclusive OR
%r_disp32
%r_disp64
Used in Sun compiler-generated code only to instruct the assembler to generate specific relocation information for the given expression.
Left shift
%r_plt32
%r_plt64
Right shift
Bitwise AND
Bitwise OR
Since these operators have the same precedence as in the C language, put expressions in parentheses to avoid ambiguity.
To avoid confusion with register names or with the %hi, %lo, %r_disp32/64, or %r_plt32/64 operators, the modulo operator % must not be immediately followed by a letter or digit. The modulo operator is typically followed by a space or left parenthesis character.
2.3.9 SPARC V9 Operators and Expressions
The following V9 64-bit operators and expressions in Table 2–4 ease the task of converting from V8/V8plus assembly code to V9 assembly code.
Table 2–4
Unary
Calculation
Operators
%hh
(address) >> 42
Extract bits 42-63 of a 64-bit word
%hm
((address) >> 32) & 0x3ff
Extract bits 32-41 of a 64-bit word
%lm
(((address) >> 10) & 0x3fffff)
Extract bits 10-31 of a 64-bit word
For example:::
sethi %hh (address), %l1
or %l1, %hm (address), %l1
sethi %lm (address), %12
or %12, %lo (address), %12
sllx %l1, 32, %l1
or %l1, %12, %l1
The V9 high 32-bit operators and expressions are identified in Table 2–5.
Table 2–5
Unary
Calculation
Operators
%hix
((((address) ^ 0xffffffffffffffff >> 10) &0x4fffff)
Invert every bit and extract bits 10-31
%lox
((address) & 0x3ff | 0x1c00
Extract bits 0-9 and sign extend that to 13 bits
For example:
%sethi %hix (address), %l1
or %l1, %lox (address), %l1
The V9 low 44-bit operators and expressions are identified in Table 2–6.
Table 2–6
Unary
Calculation
Operators
%h44
((address) >> 22)
Extract bits 22-43 of a 64-bit word
%m44
((address) >> 12) & 0x3ff
Extract bits 12-21 of a 64-bit word
l44
(address) & 0xfff
Extract bits 0-11 of a 64-bit word
For example::
%sethi %h44 (address), %l1
or %l1, %m44 (address), %l1
sllx %l1, 12, %l1
or %l1, %144 (address), %l1
