All coprocessor-operate (cpopn) instructions take all operands from and return all results to coprocessor registers. The data types supported by the coprocessor are coprocessor-dependent. Operand alignment is also coprocessor-dependent. Coprocessor-operate instructions are described in Table 5–5.
If the EC (PSR_enable_coprocessor) field of the processor state register (PSR) is 0, or if a coprocessor is not present, a cpopn instruction causes a cp_disabled trap.
The conditions that cause a cp_exception trap are coprocessor-dependent.
Table 5–5
SPARC |
Mnemonic |
Argument List |
Name |
Comments |
CPop1 |
cpop1 |
opc, regrs1, regrs2, regrd |
Coprocessor operation |
CPop2 |
cpop2 |
May modify ccc |
