System Administration Guide: Naming and Directory Services (FNS and NIS+)
Changing Root Keys From Root
Table 13–2, shows how to change the keys for the root master server from the root master (as root):
Table 13–2 Changing a Root Master's Keys: Command Summary
Tasks
Commands
Create new DES credentials
rootmaster#
nisaddcred des
Find the Process ID of rpc.nisd
rootmaster# ps -e | grep rpc.nisd
Kill the NIS+ daemon
rootmaster# kill pid
Restart NIS+ daemon with no security
rootmaster# rpc.nisd -S0
Perform a keylogout (previous keylogin is now out of date).
rootmaster# keylogout -f
Update the keys in the directories served by the master
rootmaster# nisupdkeys dirs
Restart NIS+ daemon with default security
Perform a keylogin
rootmaster# keylogin
Where:
In the first step of the process outlined in Table 13–2, nisaddcred updates the cred table for the root master, updates /etc/.rootkey and performs a keylogin for the root master. At this point the directory objects served by the master have not been updated and their credential information is now out of synch with the root master. The subsequent steps described in Table 13–2 are necessary to successfully update all the objects.
Note –
Whenever you change a server's keys, you must also update the key information of all the clients in that domain as explained in Updating Client Key Information.
