System Administration Guide: Naming and Directory Services (FNS and NIS+)
How Access Rights Are Assigned and Changed
When you create an NIS+ object, NIS+ assigns that object a default set of access rights for the owner and group classes. By default, the owner is the NIS+ principal who creates the object. The default group is the group named in the NIS_GROUP environment variable.
Specifying Different Default Rights
NIS+ provides two different ways to change the default rights that are automatically assigned to an NIS+ object when it is created.
Changing Access Rights to an Existing Object
When an NIS+ object is created, it comes into existence with a default set of access rights (from either the NIS_DEFAULTS environment variable or as specified with the -D option). These default rights can be changed with the
