System Administration Guide: Naming and Directory Services (FNS and NIS+)
Changing Root's Password
When changing root's password, you must always run chkey -p immediately after changing the password with the passwd command. Failure to run chkey -p after changing root's password will result in root being unable to properly log in.
To change a root password, follow these steps:
  1. Log in as root.
  2. Change root's password using passwd.
    Do not use nispasswd.
  3. Run chkey -p.
    You must use the -p option.
