System Administration Guide: Naming and Directory Services (FNS and NIS+)
Creating an NIS+ Group
To create an NIS+ group, you must have create rights to the groups_dir directory of the group's domain. Use the -c option and a fully qualified group name:
nisgrpadm -c group-name.
domainname
When you create a group, an NIS+ groups table with the name you have given is created in groups_dir. You can use nisls to confirm that the new group table now exists in groups_dir, and niscat to list the groups members listed in the table.
A newly created group contains no members. See Adding Members to an NIS+ Group for information on how to specify who belongs to a group.
The example below creates three groups named admin. The first is in the doc.com. domain, the second in sales.doc.com., and the third in manf.doc.com. All three are created on the master server of their respective domains.
rootmaster# nisgrpadm -c admin.doc.com.
Group admin.doc.com. created.
salesmaster# nisgrpadm -c admin.sales.doc.com.
Group admin.sales.doc.com. created.
manfmaster# nisgrpadm -c admin.manf.doc.com.
Group admin.manf.doc.com. created.
The group you create will inherit all the object properties specified in the NIS_DEFAULTS variable; that is, its owner, owning group, access rights, time-to-live, and search path. You can view these defaults by using the nisdefaults command (described in Chapter 15, Administering NIS+ Access Rights). Used without options, it provides this output:
rootmaster# nisdefaults
Principal Name : rootmaster.doc.com.
Domain Name : doc.com.
Host Name : rootmaster.doc.com.
Group Name :
Access Rights : ----rmcdr---r---
Time to live : 12:0:0
Search Path : doc.com.
The owner is listed in the Principal Name: field. The owning group is listed only if you have set the NIS_GROUP environment variable. For example, assuming a C-shell, to set NIS_GROUP to fns_admins.doc.com:
rootmaster# setenv NIS_GROUP fns_admins.doc.com
You can override any of these defaults at the time you create the group by using the -D option:
salesmaster# nisgrpadm -D group=special.sales.doc.com.-c
admin.sales.doc.com. Group admin.sales.doc.com. created.
