System Administration Guide: Naming and Directory Services (FNS and NIS+)
Changing the Time-to-Live of a Table Entry
To change the time-to-live of entries, use the indexed entry format. You can use any of the options, -A, -L, or -P.
nischttl [-ALP] time-to-live \
 [column=value,...], \
 table-name
Note –
C-shell users should use quotes to prevent the shell from interpreting the square brackets ([]) around the column value as a meta character.
These examples are similar to those above, but they change the value of table entries instead of objects:
client% nischttl 86400 '[uid=99],passwd.org_dir.doc.com.'
client% nischttl 24h `[uid=99],passwd.org_dir.doc.com.'
client% nischttl 2d1h1m1s `[name=fred],hosts.org_dir.doc.com.'
