You can initialize a client in three different ways:
By host name
By broadcast
By cold-start file
Each way has different prerequisites and associated tasks. For instance, before you can initialize a client by host name, the client's /etc/hosts or /etc/inet/ipnodes file must list the host name you will use and nsswitch.conf file must have files as the first choice on the hosts line. For IPv6 addresses, specify ipnodes as the first choice on the hosts line. Following is a summary of the steps that use the nisinit command.
To initialize a client by host name, use the -c and -H options, and include the name of the server from which the client will obtain its cold-start file:
nisinit -c -H hostname |
To initialize a client by cold-start file, use the -c and -C options, and provide the name of the cold-start file:
nisinit -c -C filename |
To initialize a client by broadcast, use the -c and -B options:
nisinit -c -B |
