System Administration Guide: Naming and Directory Services (FNS and NIS+)
Starting an NIS-Compatible Daemon
You can start the NIS+ daemon in NIS-compatibility mode in any server, including the root master. Use the -Y (uppercase) option:
rpc.nisd -Y
If the server is rebooted, the daemon will not restart in NIS-compatibility mode unless you also uncomment the line that contains EMULYP=Y in the server's /etc/init.d/rpc file.
