System Administration Guide: Naming and Directory Services (FNS and NIS+)
Searching the First Column
To search for a particular value in the first column of a table, simply enter the first column value and a tablename. In nismatch, the value must be a string. In nisgrep, the value must be a regular expression.
nismatch [-h] string tablename
nisgrep [-h] reg-expression tablename
This example searches through the depts table for all the entries whose first column has a value of R&D:
rootmaster% nismatch -h `R&D' depts.doc.com.
rootmaster% nisgrep -h `R&D' depts.doc.com.
Note –
Quotes are used in the 'R&D' expression above to prevent the shell from interpreting the ampersand (&) as a metacharacter.
