System Administration Guide: Naming and Directory Services (FNS and NIS+)
How to Stop a Machine From Using Any Server Preferences
  1. Remove the machine's /var/nis/client_info file.
    # rm /var/nis/client_info
    If the machine's domain does not have a global client_info table, this step is all you have to do. If the domain does have a client_info table, continue on to the next step.
  2. Create an empty /var/nis/client_info file.
    # touch /var/nis/client_info
    When a machine has its own /var/nis/client_info file, it does not use global preferences from any client_info table. If the machine has an empty /var/nis/client_info file, it will not use any preferences at all and will obtain NIS+ information, as described in Default Client Search Behavior.
