System Administration Guide: Naming and Directory Services (FNS and NIS+)
nisrestore Syntax
The nisrestore command uses the following syntax:
nisrestore [-fv][-a][-t] backupdir [directory_objects]
Where:
The nisrestore command takes the following options:
Table 21–2 Options for the nisbackup Command
Option
Purpose
-a
All. Restores all of the NIS+ directory objects contained in the backup directory.
-f
Forces the restoration without validating that the server is listed in the directory object's serving list. This option must be used when restoring a root master server or if you get an “unable to lookup object” type of error.
-v
Verbose mode. This mode provides additional information
-t
This option lists all of the NIS+ directory objects stored in the backup directory. No restoration of objects takes place.
