System Administration Guide: Naming and Directory Services (FNS and NIS+)
Incorrect Path
A likely cause of an “object not found” problem is specifying an incorrect path. Make sure that the path you specified is correct. Also make sure that the NIS_PATH environment variable is set correctly.
