System Administration Guide: Naming and Directory Services (FNS and NIS+)
Server Very Slow at Start-up After NIS+ Installation
Symptoms:
A server performs slowly and sluggishly after using the NIS+ scripts to install NIS+ on it.
Possible Cause:
You forgot to run nisping -C -a after running the nispopulate script.
Solution:
Run nisping -C -a to checkpoint the system as soon as you are able to do so.
