System Administration Guide: Naming and Directory Services (FNS and NIS+)
fnlist Does not List Suborganizations
Symptom:
You run fnlist with an organization name, expecting to see suborganizations, but instead see nothing.
Possible Cause:
This is caused by an NIS+ configuration problem. Suborganizations must be NIS+ domains. By definition, an NIS+ domain must have a subdirectory named org_dir.
Diagnosis:
Use the nisls command to see what subdirectories exist. Run nisls on each subdirectory to verify which subdirectories have an org_dir. The subdirectories with an org_dir are suborganizations.
Solution:
Not applicable.
