The input file supplies the names and values to be bound in the context of composite_name. Its format is based upon and similar, but not identical, to the format of indirect automount maps. The input file contains one or more entries with the form:
name [options] [location...] |
name is the reference name. The name field may be a simple atomic name or a slash-separated hierarchical name. It may also be “.” (dot), in which case the reference is bound directly to composite_name.
options are mount options, if any. The options field begins with a hyphen (“–”). This is followed by a comma-separated list (with no spaces) of the mount options to use when mounting the directory. These options also apply to any subcontexts of composite_name/name that do not specify mount options of their own.
location is the mount location. The location field specifies the host or hosts that serve the files for composite_name/name. In a simple NFS mount, location takes the form:
host:path |
Where host is the name of the server from which to mount the file system and path is the path name of the directory to mount.
For each entry a reference to the mount locations and the corresponding mount options is bound to the name composite_name/name.
If options and location are both omitted, then no reference is bound to composite_name/name. Any existing reference is unbound.
For example, suppose you want kuanda's file system to be an NFS mount of the directory /export/home/kuanda from host altair as shown in Figure 25–3. The command would be run as follows:
% fncreate_fs -f infile user/kuanda/fs |
. altair:/export/home/kuanda |
To set up a more complex file system distributed over more than one server as shown in Figure 25–4, run the command
% fncreate_fs -f infile org/sales/fs |
with infile containing
tools/db altair:/export/db project altair:/export/proj project/lib altair:/export/lib project/src deneb:/export/src |
To change the NFS mounts for project and its subcontexts src and lib to be read-only, you can change infile as follows:
tools/db svr1:/export/db project -ro svr1:/export/projproject/lib altair:/export/lib project/src svr2:/export/src |
The -ro is unnecessary in the third and fourth lines because src and lib are subcontexts of project, they will inherit the -ro mount option from above.
The following input file would make all of the mounts read-only except for org/sales/fs/project/src.
. -ro tools/db svr1:/export/db project svr1:/export/proj project/lib altair:/export/lib project/src -rw svr2:/export/src |
