System Administration Guide: Naming and Directory Services (FNS and NIS+)
Some Common Error Messages
attribute no permission
:. The caller did not have permission to perform the attempted attribute operation.
attribute value required
:. The operation attempted to create an attribute without a value, and the specific naming system does not allow this.
authentication failure
:. The operation could not be completed because the principal making the request cannot be authenticated with the name service involved. If the service is NIS+, check that you are identified as the correct principal (run the command nisdefaults) and that your machine has specified the correct source for publickeys. Check that the /etc/nsswitch.conf file has the entry, publickey: nisplus.
bad reference
:. FNS could not interpret the contents of the reference. This can result if the contents of the reference have been corrupted or when the reference identifies itself as an FNS reference, but FNS doesn't know how to decode it.
Cannot obtain Initial Context
:. Indicates an installation problem. See Cannot Obtain Initial Context.
communication failure
:. FNS could not communicate with the name service to complete the operation.
configuration error
An error resulted because of configuration problems. Examples:
(1) The bindings table is removed out-of-band (outside of FNS).
(2) A host is in the NIS+ hosts directory object but does not have a corresponding FNS host context.
context not empty
:. An attempt has been made to remove a context that still contains bindings.
continue operation using status values
:. The operation should be continued using the remaining name and the resolved reference returned in the status.
error
:. An error that cannot be classified as one of the other errors listed above occurred while processing the request. Check the status of the naming services involved in the operation and see whether any of them are experiencing extraordinary problems.
illegal name
:. The name supplied is not a legal name.
incompatible code sets
:. The operation involved character strings from incompatible code sets, or the supplied code set is not supported by the implementation.
invalid enumeration handle
:. The enumeration handle supplied is invalid. The handle could have been from another enumeration, an update operation might have occurred during the enumeration, or there might have been some other reason.
invalid syntax attributes
:. The syntax attributes supplied are invalid or insufficient to fully specify the syntax.
link error
:. An error occurred while resolving an XFN link with the supplied name.
malformed link
:. A malformed link reference was found during a fn_ctx_lookup_link() operation. The name supplied resolved to a reference that was not a link.
name in use
:. The name supplied is already bound in the context.
name not found
:. The name supplied was not found.
no permission
:. The operation failed because of access control problems. See “No Permission” Messages (FNS). See also No Permission.
no such attribute
:. The object did not have an attribute with the given identifier.
no supported address
:. No shared library could be found under the /usr/lib/fn directory for any of the address types found in the reference bound to the FNS name. Shared libraries for an address type are named according to this convention: fn_ctx_address_type.so. Typically there is a link from fn_ctx_address_type.so to fn_ctx_address_type.so.1.
For example, a reference with address type onc_fn_nisplus would have a shared library in the path name: /usr/lib/fn/fn_ctx_onc_fn_nisplus.so.
not a context
:. The reference does not correspond to a valid context.
partial result returned
:. The operation returned a partial result.
Success
(1) The request was successful. This message is generated by the NIS+ error code constant: NIS_SUCCESS. See the nis_tables man page for additional information.
(2) :. Operation succeeded.
syntax not supported
:. The syntax type is not supported.
too many attribute values
:. The operation attempted to associate more values with an attribute than the naming system supports.
unavailable
:. The name service on which the operation depends is unavailable.
link loop limit reached
:. A nonterminating loop was detected due to XFN links encountered during composite name resolution, or the implementation-defined limit was exceeded on the number of XFN links allowed for a single operation.
