Solaris Volume Manager Administration Guide
Optimized Resynchronization
During a reboot following a system failure, or when a submirror that was offline is brought back online, Solaris Volume Manager performs an optimized mirror resynchronization. The metadisk driver tracks submirror regions and knows which submirror regions might be out-of-sync after a failure. An optimized mirror resynchronization is performed only on the out-of-sync regions. You can specify the order in which mirrors are resynchronized during reboot, and you can omit a mirror resynchronization by setting submirror pass numbers to 0 (zero). (See Pass Number for information.)
Caution – Caution –
A pass number of 0 (zero) should only be used on mirrors that are mounted as read-only.
