Solaris Volume Manager Administration Guide
RAID 1 Volume Configuration Guidelines
Note –
If you have a mirrored file system in which the first submirror attached does not start on cylinder 0, all additional submirrors you attach must also not start on cylinder 0. If you attempt to attach a submirror starting on cylinder 0 to a mirror in which the original submirror does not start on cylinder 0, the following error message displays:
can't attach labeled submirror to an unlabeled mirror
You must ensure that all submirrors intended for use within a specific mirror either all start on cylinder 0, or that none of them start on cylinder 0.
Starting cylinders do not have to be the same across all submirrors, but all submirrors must either include or not include cylinder 0.
