System Administration Guide: Basic Administration
Example—Restoring Files From a Remote Tape Device
You can restore files from a remote tape drive by adding remote-host: to the front of the tape device name, when using the ufsrestore command.
The following example shows how to restore files using a remote tape drive /dev/rmt/0 on the system venus.
# ufsrestore xf venus:/dev/rmt/0 ./etc/hosts
