The following example shows how to do a full backup of a local /export/home file system on a Solaris 9 system (starbug) to a tape device on a remote Solaris 9 system (earth).The following ufsdump options are included:
0 specifies that this is a 0 level dump (or a full backup)
u specifies that the /etc/dumpdates file is updated with the date of this backup
c identifies a cartridge tape device
f earth:/dev/rmt/0 identifies the remote system name and tape device
/export/home is the file system being backed up
# ufsdump 0ucf earth:/dev/rmt/0 /export/home DUMP: Writing 63 Kilobyte records DUMP: Date of this level 0 dump: Wed Sep 05 14:52:31 2001 DUMP: Date of last level 0 dump: the epoch DUMP: Dumping /dev/rdsk/c0t0d0s7 (starbug:/export/home) to earth:/dev ... DUMP: Mapping (Pass I) [regular files] DUMP: Mapping (Pass II) [directories] DUMP: Estimated 266 blocks (133KB). DUMP: Dumping (Pass III) [directories] DUMP: Dumping (Pass IV) [regular files] DUMP: Tape rewinding DUMP: 250 blocks (125KB) on 1 volume at 247 KB/sec DUMP: DUMP IS DONE DUMP: Level 0 dump on Wed Sep 05 14:52:31 2001 # ufsrestore tf earth:/dev/rmt/0 2 . 3 ./lost+found 7168 ./rimmer 7169 ./rimmer/.profile 21504 ./rimmer/scdir 21505 ./rimmer/scdir/scd557 21506 ./rimmer/scdir/scd772 10752 ./lister 10753 ./lister/.profile 10754 ./lister/filea 10755 ./lister/fileb 10756 ./lister/filec 14336 ./pmorph 14337 ./pmorph/.profile 3584 ./pmorph/bigdir 3585 ./pmorph/bigdir/bigfile 17920 ./pmorph/smalldir 17921 ./pmorph/smalldir/smallfile # |
