System Administration Guide: Basic Administration
SPARC: Disks With Bus-Oriented Controllers
To specify a slice on a disk with a bus-oriented controller, SCSI for instance, on a SPARC based system, follow the naming convention shown in the following figure.
Figure 29–3 SPARC: Disks With Bus-Oriented Controllers
Diagram shows device name for disks with bus-oriented controllers that includes logical controller, physical bus target, drive, and slice or fdisk partition.
On a SPARC based system with directly connected disks such as the IDE disks on a Ultra10, the naming convention is the same as that for systems with bus-oriented controllers.
If you have only one controller on your system, w is usually 0.
For SCSI controllers, x is the target address set by the switch on the back of the unit, and y is the logical unit number (LUN) of the drive attached to the target. If the disk has an embedded controller, y is usually 0.
To indicate the whole disk, specify slice 2 (s2).
