System Administration Guide: Basic Administration
Examples—Displaying Disk Slice Information
The following example displays slice information for disk /dev/dsk/c0t3d0.
# format
Searching for disks...done
Specify disk (enter its number):1
Selecting c0t3d0
format> partition
partition> print
Current partition table (original):
Total disk cylinders available: 2036 + 2 (reserved cylinders)
Part      Tag    Flag     Cylinders        Size            Blocks
  0       root    wm       0 -  300      148.15MB    (301/0/0)   303408
  1       swap    wu     301 -  524      110.25MB    (224/0/0)   225792
  2     backup    wm       0 - 2035     1002.09MB    (2036/0/0) 2052288
  3 unassigned    wm       0               0         (0/0/0)          0
  4 unassigned    wm       0               0         (0/0/0)          0
  5 unassigned    wm       0               0         (0/0/0)          0
  6        usr    wm     525 - 2035      743.70MB    (1511/0/0) 1523088
  7 unassigned    wm       0               0         (0/0/0)          0
partition> q
format> q
For a detailed description of the slice information in these examples, see Chapter 31, Managing Disks (Overview).
The following example shows the slice information on disk /dev/dsk/c0t0d0.
# format
Specify disk (enter its number): 0
selecting c0t0d0
[disk formatted]
format> partition
partition> print
Total disk cylinders available: 817 + 2 (reserved cylinders)
  0 unassigned    wm       3 - 816        6.26GB    (814/0/0) 13128192
  1 unassigned    wm       0              0         (0/0/0)          0
  2     backup    wm       0 - 816        6.28GB    (817/0/0) 13176576
  6 unassigned    wm       0              0         (0/0/0)          0
  8       boot    wu       0 -   0        7.88MB    (1/0/0)      16128
  9 alternates    wu       1 -   2       15.75MB    (2/0/0)      32256
partition> q
format> q
