System Administration Guide: Basic Administration
Where to Go From Here
Check the following table if the format utility did not recognize a disk.
Disk Problem
To Solve the Problem
Disk is newly added and you didn't perform a reconfiguration boot
Go to Chapter 33, SPARC: Adding a Disk (Tasks) or Chapter 34, x86: Adding a Disk (Tasks).
Disk is a third-party disk
Go to Creating a format.dat Entry.
Label was corrupted by a system problem, such as a power failure
Go to How to Label a Disk.
Disk is not properly connected to the system
Connect the disk to the system by using your disk hardware documentation.
