You might want to view certain information about a specific CacheFS file system. The following table explains the terminology that is displayed in the statistics output.
Table 40–2 CacheFS Statistics Terminology
Output Term |
Description |
cache hit rate |
The rate of cache hits versus cache misses, followed by the actual number of hits and misses. A cache hit occurs when the user wants to perform an operation on a file or files, and the file or files are actually in the cache. A cache miss occurs when the file is not in the cache. The load on the server is the sum of cache misses, consistency checks, and modifications (modifies). |
consistency checks |
The number of consistency checks performed, followed by the number that passed, and the number that failed. |
modifies |
The number of modify operations. For example, writes or creates. |
