System Administration Guide: Basic Administration
Examples—Mounting All File Systems (/etc/vfstab File)
The following example shows the messages that are displayed if file systems are already mounted when you use the mountall command.
# mountall
/dev/rdsk/c0t0d0s7 already mounted
mount: /tmp already mounted
mount: /dev/dsk/c0t0d0s7 is already mounted, /export/home is busy,
        or the allowable number of mount points has been exceeded
All the file systems with a device to fsck entry are checked and fixed, if necessary, before they are mounted.
The following example shows how to mount all the local systems that are listed in the /etc/vfstab file.
# mountall -l
# mount
/ on /dev/dsk/c0t0d0s0 read/write/setuid/intr/largefiles/xattr/onerror= ...
/usr on /dev/dsk/c0t0d0s6 read/write/setuid/intr/largefiles/xattr/ ...
/proc on /proc read/write/setuid/dev=38c0000 on Tue Oct 30 15:45:32 2001
/etc/mnttab on mnttab read/write/setuid/dev=3980000 on Tue Oct 30  ...
/dev/fd on fd read/write/setuid/dev=39c0000 on Tue Oct 30 15:45:36 2001
/var/run on swap read/write/setuid/xattr/dev=1 on Tue Oct 30 15:45:39 ...
/tmp on swap read/write/setuid/xattr/dev=2 on Tue Oct 30 16:05:57 2001
/datab on /dev/dsk/c0t0d0s7 read/write/setuid/intr/largefiles/xattr/ ...
The following example shows how to mount all of the remote file systems that are listed in the /etc/vfstab file.
# mountall -r
# mount
/usr on /dev/dsk/c0t0d0s6 read/write/setuid/intr/largefiles/xattr/onerror= ...
/var/run on swap read/write/setuid/xattr/dev=1 on Tue Oct 30 15:45:39 2001
/home/rimmer on pluto:/export/home/rimmer remote/read/write/setuid/xattr ...
