This example shows how to use the mount command to display information about the file systems that are currently mounted.
$ mount / on /dev/dsk/c0t0d0s0 read/write/setuid/intr/largefiles/xattr/onerror= ... /usr on /dev/dsk/c0t0d0s6 read/write/setuid/intr/largefiles/xattr/onerror= ... /proc on /proc read/write/setuid/dev=4300000 on Fri Nov 30 11:25:13 2001 /etc/mnttab on mnttab read/write/setuid/dev=43c0000 on Fri Nov 30 11:25:13 ... /dev/fd on fd read/write/setuid/dev=4400000 on Fri Nov 30 11:25:17 2001 /var/run on swap read/write/setuid/xattr/dev=1 on Fri Nov 30 11:25:20 2001 /tmp on swap read/write/setuid/xattr/dev=2 on Fri Nov 30 11:25:24 2001 /export on /dev/dsk/c0t0d0s4 read/write/setuid/intr/largefiles/xattr/ ... /export/home on /dev/dsk/c0t0d0s7 read/write/setuid/intr/largefiles/ ... $ |
