System Administration Guide: Basic Administration
The Virtual File System Table
It would be a very time-consuming and error-prone task to manually mount file systems every time you wanted to access them. To avoid this problem, the virtual file system table (the /etc/vfstab file) provides a list of file systems and how to mount them.
The /etc/vfstab file provides two important features:
A default /etc/vfstab file is created when you install a system, depending on the selections you make when installing system software. However, you can edit the /etc/vfstab file on a system whenever you want. To add an entry, the main information you need to specify is the device where the file system resides, the name of the mount point, the type of the file system, whether you want the file system to mount automatically when the system boots (by using the mountall command), and any mount options.
The following is an example of an /etc/vfstab file. Comment lines begin with #. This example shows an /etc/vfstab file for a system with two disks (c0t0d0 and c0t3d0).
$ more /etc/vfstab
#device         device          mount           FS      fsck   mount  mount
#to mount       to fsck         point           type    pass   at boot options
/dev/dsk/c0t0d0s0 /dev/rdsk/c0t0d0s0 /          ufs     1       no      -
/proc           -               /proc           proc    -       no      -
/dev/dsk/c0t0d0s1 -                -            swap    -       no      -
swap            -               /tmp            tmpfs   -       yes     -
/dev/dsk/c0t0d0s6 /dev/rdsk/c0t0d0s6 /usr       ufs     2       no      -
/dev/dsk/c0t3d0s7 /dev/rdsk/c0t3d0s7 /test      ufs     2       yes     -
In the preceding example, the last entry specifies that a UFS file system on the /dev/dsk/c0t3d0s7 slice will be automatically mounted on the /test mount point when the system boots. Note that, for root (/) and /usr, the mount at boot field value is specified as no, because these file systems are mounted by the kernel as part of the boot sequence before the mountall command is run.
For descriptions of each of the /etc/vfstab fields and information on how to edit and use the file, see Chapter 39, Mounting and Unmounting File Systems (Tasks).
