System Administration Guide: Basic Administration
Additional Virtual File Systems
These additional types of virtual file systems are listed for your information. They do not require administration.
Virtual File System
Description
FIFOFS (first-in first-out)
Named pipe files that give processes common access to data
FDFS (file descriptors)
Provides explicit names for opening files using file descriptors
MNTFS
Provides read-only access to the table of mounted file systems for the local system
NAMEFS
Used mostly by STREAMS for dynamic mounts of file descriptors on top of files
SPECFS (special)
Provides access to character special devices and block devices
SWAPFS
Used by the kernel for swapping
