System Administration Guide: Basic Administration
Example—Checking the Contents of Installed Software Packages
The following example shows how to check the contents of a package.
# pkgchk -c SUNWbash
If no errors occur, the system prompt is returned. Otherwise, the pkgck command reports the error.
