System Administration Guide: Basic Administration
Fields in the passwd File
The fields in the passwd file are separated by colons and contain the following information:
username:password:uid:gid:comment:home-directory:login-shell
For example:
kryten:x:101:100:Kryten Series 4000 Mechanoid:/export/home/kryten:/bin/csh
The following table describes the passwd file fields.
Table 4–11 Fields in the passwd File
Field Name
Description
username
Contains the user or login name. User names should be unique and consist of 1-8 letters (A-Z, a-z) and numerals (0-9). The first character must be a letter, and at least one character must be a lowercase letter.
password
Contains an x, a placeholder for the encrypted password. The encrypted password is stored in the shadow file.
uid
Contains a user identification (UID) number that identifies the user to the system. UID numbers for regular users should range from 100 to 60000. All UID numbers should be unique.
gid
Contains a group identification (GID) number that identifies the user's primary group. Each GID number must be a whole number between 0 and 60002. 60001 and 60002 are assigned to nobody and noaccess. 65534 is assigned to nobody4.
comment
Usually contains the full name of the user. This field is informational only. It is sometimes called the GECOS field because it was originally used to hold the login information needed to submit batch jobs to a mainframe running GECOS (General Electric Computer Operating System) from UNIX systems at Bell Labs.
home-directory
Contains the user's home directory path name.
login-shell
Contains the user's default login shell, such as /bin/sh, /bin/csh or /bin/ksh. Table 4–18 contains a description of shell features.
Default passwd File
The default Solaris passwd file contains entries for standard daemons, processes usually started at boot time to perform some system-wide task, such as printing, network administration, and port monitoring.
root:x:0:1:Super-User:/:/sbin/sh
daemon:x:1:1::/:
bin:x:2:2::/usr/bin:
sys:x:3:3::/:
adm:x:4:4:Admin:/var/adm:
lp:x:71:8:Line Printer Admin:/usr/spool/lp:
uucp:x:5:5:uucp Admin:/usr/lib/uucp:
nuucp:x:9:9:uucp Admin:/var/spool/uucppublic:/usr/lib/uucp/uucico
smmsp:x:25:25:SendMail Message Submission Program:/:
listen:x:37:4:Network Admin:/usr/net/nls:
nobody:x:60001:60001:Nobody:/:
noaccess:x:60002:60002:No Access User:/:
nobody4:x:65534:65534:SunOS 4.x Nobody:/:
Table 4–12 Default passwd File Entries
User Name
User ID
Description
root
0
Superuser account.
daemon
1
Umbrella system daemon associated with routine system tasks.
bin
2
Administrative daemon associated with running system binaries to perform some routine system task.
sys
3
Administrative daemon associated with system logging or updating files in temporary directories.
adm
4
Administrative daemon associated with system logging.
lp
71
Line printer daemon.
uucp
5
Daemon associated with uucp functions.
nuucp
6
smmsp
25
Sendmail message submission program daemon.
listen
37
Network listener daemon.
nobody
60001
Assigned to users or software processes that do not need nor should have any special permissions.
noaccess
60002
Assigned to a user or a process that needs access to a system through some application but without actually logging in.
nobody4
65534
SunOS 4.0 or 4.1 version of the nobody user account.
