Solaris WBEM Developer's Guide
Passing a Class to the Association Methods
To specify the name of a class, you specify its model path. The model path includes the class's namespace, class name, and keys. A key is a property or set of properties that uniquely identify managed resource. Key properties are marked with the key qualifier. The following example shows a sample model path:
mycomputer: CreationClassName=Solaris_ComputerSystem
This model path specifies the following values:
