Solaris WBEM Developer's Guide
Solaris_NamespaceAcl Class
The Solaris_NamespaceAcl inherits the string property capability with a default value r (read-only for all users) from the Solaris_Acl class. The Solaris_NamespaceAcl class defines this key property.
Data Type
Identifies the namespace to which this access control list applies. Only one instance of the namespace ACL can exist in a namespace.
How to Set Access Control for a Namespace
  1. Create an instance of the Solaris_namespaceAcl class.
    For example:
    /* Create a namespace object initialized with root\security
    (name of namespace) on the local host. */
    CIMNameSpace cns = new CIMNameSpace("", "root\security");
    // Connect to the root\security namespace as root.
    cc = new CIMClient(cns, user, user_passwd);
    // Get the Solaris_namespaceAcl class
    cimclass = cc.getClass(new CIMObjectPath("Solaris_namespaceAcl");
    // Create a new instance of the Solaris_namespaceAcl
    class ci = cimclass.newInstance();
  2. Set the capability property to the desired access rights.
    For example:
    /* Change the access rights (capability) to read/write
    to the root\molly namespace. */
    ci.setProperty("capability", new CIMValue(new String("rw"));
    ci.setProperty("nspace", new CIMValue(new String("root\molly"));
  3. Update the instance.
    For example:
    // Pass the updated instance to the CIM Object Manager
    cc.createInstance(new CIMObjectPath(), ci);
