Solaris WBEM Developer's Guide
Calling Methods
You use the invokeMethod interface to call a method in a class supported by a provider. To retrieve the signature of a method, an application must first get the definition of the class to which the method belongs. The invokeMethod method returns a CIMValue. The return value is null when the method that you invoke does not define a return value.
The invokeMethod interface takes four arguments, as described in the following table.
Table 4–4 invokeMethod Parameters
Parameter
Data Type
Description
name
CIMObjectPath
The name of the instance on which the method must be invoked
methodName
String
The name of the method to call
inParams
Vector
Input parameters to pass to the method
outParams
Vector
Output parameters to get from the method
Example 4–15 Calling a Method
This example gets the instances of the CIM_Service class, which represent services that manage device or software features. The example uses the invokeMethod method to stop each service.
    /* Pass the CIM Object Path of the CIM_Service class
    to the CIM Object Manager. We want to invoke a method defined in
    this class. */
    CIMObjectPath op = new CIMObjectPath("CIM_Service");
    /* The CIM Object Manager returns an enumeration of instance
    object paths, the names of instances of the CIM_Service
    class. */
    Enumeration e = cc.enumerateInstanceNames (op, true);
    /* Iterate through the enumeration of instance object paths */
    while(e.hasMoreElements()) {
                // Get the instance
                CIMObjectPath op = (CIMObjectPath) e.nextElement();
                //Invoke the Stop Service method to stop the CIM services.
                cc.invokeMethod("StopService", null, null);
