This following sample code implements the enumerateInstances and getInstance interfaces for the Ex_SimpleCIMInstanceProvider class. For brevity, this example implements the deleteInstance, createInstance, setInstance, and execQuery interfaces by throwing a CIMException.
For information on implementing the execQuery method, see Parsing Queries.
/* * "@(#)SimpleCIMInstanceProvider.java" */ import javax.wbem.cim.*; import javax.wbem.client.*; import javax.wbem.provider.CIMProvider; import javax.wbem.provider.CIMInstanceProvider; import javax.wbem.provider.MethodProvider; import java.util.*; import java.io.*; public class SimpleCIMInstanceProvider implements CIMInstanceProvider { static int loop = 0; public void initialize(CIMOMHandle cimom) throws CIMException { } public void cleanup() throws CIMException { } public CIMObjectPath[] enumerateInstanceNames(CIMObjectPath op, CIMClass cc) throws CIMException { return null; } /* * enumerateInstances: * The entire instances and not just the names are returned. */ public CIMInstance[] enumerateInstances(CIMObjectPath op, boolean localOnly,boolean includeQualifiers, boolean includeClassOrigin,String[] propertyList, CIMClass cc) throws CIMException { if (op.getObjectName().equalsIgnoreCase ("Ex_SimpleCIMInstanceProvider")) { Vector instances = new Vector(); CIMInstance ci = cc.newInstance(); if (loop == 0){ ci.setProperty("First", new CIMValue("red")); ci.setProperty("Last", new CIMValue("apple")); // only include the properties that were requested ci = ci.filterProperties(propertyList, includeQualifier, includeClassOrigin); instances.addElement(ci); loop += 1; } else { ci.setProperty("First", new CIMValue("red")); ci.setProperty("Last", new CIMValue("apple")); // only include the requested properties ci = ci.filterProperties(propertyList, includeQualifier, includeClassOrigin); instances.addElement(ci); ci = cc.newInstance(); ci.setProperty("First", new CIMValue("green")); ci.setProperty("Last", new CIMValue("apple")); // only include the requested properties ci = ci.filterProperties(propertyList, includeQualifier, includeClassOrigin); instances.addElement(ci); } return (CIMInstance[])instances.toArray(); } throw new CIMException(CIM_ERR_INVALID_CLASS); } public CIMInstance getInstance(CIMObjectPath op, boolean localOnly, boolean includeQualifiers, boolean includeClassOrigin, String[] propertyList, CIMClass cc) throws CIMException { if (op.getObjectName().equalsIgnoreCase ("Ex_SimpleCIMInstanceProvider")) { CIMInstance ci = cc.newInstance(); // we need to get the keys from the passed in object path, // this will uniquely identify the instance we want to get java.util.Vector keys = cop.getKeys(); // Since this is a contrived example we will simply place // the keys into the instance and be done. ci.setProperties(keys); // if we had other non-key properties we should add them //here. // only include the properties that were requested ci = ci.filterProperties(propertyList, includeQualifiers, includeClassOrigin); return ci; } throw new CIMException(CIM_ERR_INVALID_CLASS); } public CIMInstance[] execQuery(CIMObjectPath op, \ String query, String ql, CIMClass cc) throws CIMException { throw(new CIMException(CIMException.CIM_ERR_NOT_SUPPORTED)); } public void setInstance(CIMObjectPath op, CIMInstance ci, boolean includeQualifiers, String[] propertyList) throws CIMException { throw(new CIMException(CIMException.CIM_ERR_NOT_SUPPORTED)); } public CIMObjectPath createInstance(CIMObjectPath op, CIMInstance ci) throws CIMException { throw(new CIMException( CIMException.CIM_ERR_NOT_SUPPORTED)); } public void deleteInstance(CIMObjectPath cp) throws CIMException { throw(new CIMException(CIMException.CIM_ERR_NOT_SUPPORTED)); } }
