System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Keyserver and publickey Entry in the Switch File
Caution – Caution –
You must restart the keyserver after you make a change to nsswitch.conf
The keyserver reads the publickey entry in the name service switch configuration file only when the keyserver is started. As a result, if you change the switch configuration file, the keyserver does not become aware of changes to the publickey entry until it is restarted.
