System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
SSDs
The serviceSearchDescriptor attribute defines how and where an LDAP naming service client should search for information for a particular service. The serviceSearchDescriptor contains a service name, followed by one or more semicolon-separated base-scope-filter triples. These base-scope-filter triples are used to define searches only for the specific service and are searched in order. If multiple base-scope-filters are specified for a given service, then when that service looks for a particular entry, it will search in each base with the specified scope and filter.
Note –
The default location is not searched for a service (database) with an SSD unless it is included in the SSD. Unpredictable behavior will result if multiple SSDs are given to a service.
In the following example, the Solaris LDAP naming service client performs a one-level search in ou=west,dc=example,dc=com followed by a one-level search in ou=east,dc=example,dc=com for the passwd service. To look up the passwd data for a user's username, the default LDAP filter (&(objectClass=posixAccount)(uid=username)) is used for each BaseDN.
serviceSearchDescriptor: passwd:ou=west,dc=example,dc=com;ou=east,
dc=example,dc=com
In the following example, the Solaris LDAP naming service client would perform a subtree search in ou=west,dc=example,dc=com for the passwd service. To look up the passwd data for user username, the subtree ou=west,dc=example,dc=com would be searched with the LDAP filter (&(fulltimeEmployee=TRUE)(uid=username)).
dc=com?sub?fulltimeEmployee=TRUE
It is also possible to associate multiple containers with a particular service type.
For example, the following service search descriptor specifies that the three containers, ou=myuser,dc=example,dc=com, ou=newuser,dc=example,dc=com, and ou=extuser,dc=example,dc=com are searched for the password entries. Note that a trailing ',' implies that the defaultSearchBase is appended to the relative base in the SSD.
defaultSearchBase: dc=example,dc=com
serviceSearchDescriptor: \
passwd:ou=myuser;ou=newuser,ou=extuser,dc=example,dc=com
Attribute Map
The Solaris LDAP naming service allows one or more attribute names to be remapped for any of its services. (The Solaris LDAP client uses the well-known attributes documented in Chapter 18, General Reference (Reference).) If you map an attribute, you must be sure that the attribute has the same meaning and syntax as the original attribute. Note that mapping the userPassword attribute might cause problems.
There are a couple of reasons you might want to use schema mappings.
The format is service:attribute-name=mapped-attribute-name.
If you want to map more than one attribute for a given service, you can define multiple attributeMap attributes.
In the following example, the employeeName and home attributes would be used whenever the uid andhomeDirectory attributes would be used for the passwd service.
attributeMap: passwd:uid=employeeName
attributeMap: passwd:homeDirectory=home
There exists one special case where you can map the passwd service's gecos attribute to several attributes. The following is an example.
attributemap: gecos=cn sn title
This maps the gecos values to a space-separated list of the cn, sn, and title attribute values.
objectClass Map
The Solaris LDAP naming service allows object classes to be remapped for any of its services. If you want to map more than one object class for a given service, you can define multiple objectclassMap attributes. In the following example, the myUnixAccount object class is used whenever the posixAccount object class is used.
objectclassMap: passwd:posixAccount=myUnixAccount
