TLS can be used to secure communication between an LDAP client and the directory server, providing both privacy and data integrity. The TLS protocol is a super set of the Secure Sockets Layer (SSL) protocol. The Solaris LDAP naming service supports TLS connections. Be aware that using SSL will add load to the directory server and the client.
You will need to set up your directory server for SSL. See the iPlanet Directory Server 5.1 Administrator's Guide for more information on setting up the iPlanet Directory Server 5.1 for SSL. You will also need to set up your LDAP client for SSL.
In order to use TLS for the Solaris LDAP naming service, the directory server must use the default ports, 389 and 636, for LDAP and SSL, respectively. If your directory server does not use these ports, you cannot use TLS at this time.
See TLS Security Setup for more information.
