System Administration Guide: Naming and Directory Services (FNS and NIS+)
Two Configuration Methods
The rest of this part of the manual describes two different methods of configuring an NIS+ namespace:
Note –
If you use the NIS+ command set, you must also make sure that each machine using NIS+ for its name service has the correct nsswitch.conf file in its /etc directory as described in Chapter 1, The Name Service Switch. If you use the NIS+ configuration scripts on a given machine, this step is performed for you.
See Chapter 22, Removing NIS+ for information on how to remove an NIS+ directory or domain, an NIS+ server, or the NIS+ namespace.
