This procedure shows how to set up CHAP credentials for two trusted callers. The steps in the procedure assume that you, the system administrator, are creating the CHAP credentials on the trusted callers' dial-out machines.
Become superuser on a dial-out machine.
Using the sample CHAP configuration that was introduced in "Example-Configuration Using CHAP Authentication", assume that the dial-out machine belongs to trusted caller account1.
Modify the chap-secrets database for caller account1.
Solaris PPP 4.0 includes an /etc/ppp/chap-secrets file that has helpful comments but no options. You can add the following options to this existing /etc/ppp/chap-secrets file.
# account1 CallServe key123 * |
CallServe is the name for the peer that account1 is trying to reach. key123 is the CHAP secret to be used for links between account1 and CallServer.
Become superuser on another dial-out machine.
Assume that this machine belongs to caller account2.
Modify the /etc/ppp/chap-secrets database for caller account2.
# account2 CallServe key456 * |
Now account2 has secret key456 as its CHAP credentials for use over links to peer CallServe.
Task |
For Instructions |
Create CHAP credentials on the dial-out machines of trusted callers |
"How to Create a CHAP Credentials Database (Dial-in Server)" |
Configure a dial-out machine to support CHAP authentication |
"How to Configure CHAP Authentication Credentials for the Trusted Callers" |
