System Administration Guide: Resource Management and Network Services
WebNFS Limitations With Web Browser Use
Several functions that a Web site that uses HTTP can provide are not supported by the WebNFS software. These differences stem from the fact that the NFS server only sends the file, so any special processing must be done on the client. If you need to have one web site configured for both WebNFS and HTTP access, consider the following issues:
