Programming Interfaces Guide
Interval Timer Interfaces
Real-time applications often schedule actions by using interval timers. Interval timers can be either of two types: a one-shot type or a periodic type.
A one-shot is an armed timer that is set to an expiration time relative to either a current time or an absolute time. The timer expires once and is disarmed. This type of a timer is useful for clearing buffers after the data has been transferred to storage, or to time-out an operation.
A periodic timer is armed with an initial expiration time, either absolute or relative, and a repetition interval. Every time the interval timer expires, the timer is reloaded with the repetition interval. The timer is then rearmed. This timer is useful for data logging or for servo-control. In calls to interval timer interfaces, time values that are smaller than the timer's resolution are rounded up to the next multiple of the hardware timer interval. This interval is typically 10ms.
SunOS has two sets of timer interfaces. The setitimer(2) and getitimer(2) interfaces operate fixed set timers, which are called the BSD timers, using the timeval structure to specify time intervals. The POSIX timers, which are created with timer_create(3RT), operate the POSIX clock, CLOCK_REALTIME. POSIX timer operations are expressed in terms of the timespec structure.
The getitimer(2) and setitimer(2) functions retrieve and establish, respectively, the value of the specified BSD interval timer. The three BSD interval timers that are available to a process include a real-time timer designated ITIMER_REAL. If a BSD timer is armed and allowed to expire, the system sends an appropriate signal to the process that set the timer.
The timer_create(3RT) routine can create up to TIMER_MAX POSIX timers. The caller can specify what signal and what associated value are sent to the process when the timer expires. The timer_settime(3RT) and timer_gettime(3RT) routines retrieve and establish respectively the value of the specified POSIX interval timer. POSIX timers can expire while the required signal is pending delivery. The timer expirations are counted, and timer_getoverrun(3RT) retrieves the count. timer_delete(3RT) deallocates a POSIX timer.
The following example illustrates how to use setitimer(2) to generate a periodic interrupt, and how to control the arrival of timer interrupts.
Example 10–2 Controlling Timer Interrupts
#include	<unistd.h>
#include	<signal.h>
#include	<sys/time.h>
#define TIMERCNT 8
void timerhandler();
int	 timercnt;
struct	 timeval alarmtimes[TIMERCNT];
main()
	struct itimerval times;
	sigset_t	sigset;
	int		i, ret;
	struct sigaction act;
	siginfo_t	si;
	/* block SIGALRM */
	sigemptyset (&sigset);
	sigaddset (&sigset, SIGALRM);
	sigprocmask (SIG_BLOCK, &sigset, NULL);
	/* set up handler for SIGALRM */
	act.sa_action = timerhandler;
	sigemptyset (&act.sa_mask);
	act.sa_flags = SA_SIGINFO;
	sigaction (SIGALRM, &act, NULL);
	 * set up interval timer, starting in three seconds,
	 *	then every 1/3 second
	times.it_value.tv_sec = 3;
	times.it_value.tv_usec = 0;
	times.it_interval.tv_sec = 0;
	times.it_interval.tv_usec = 333333;
	ret = setitimer (ITIMER_REAL, &times, NULL);
	printf ("main:setitimer ret = %d\n", ret);
	/* now wait for the alarms */
	timerhandler (0, si, NULL);
	while (timercnt < TIMERCNT) {
		ret = sigsuspend (&sigset);
	printtimes();
void timerhandler (sig, siginfo, context)
	int		sig;
	siginfo_t	*siginfo;
	void		*context;
	printf ("timerhandler:start\n");
	gettimeofday (&alarmtimes[timercnt], NULL);
	timercnt++;
	printf ("timerhandler:timercnt = %d\n", timercnt);
printtimes ()
	int	i;
	for (i = 0; i < TIMERCNT; i++) {
		printf("%ld.%0l6d\n", alarmtimes[i].tv_sec,
				alarmtimes[i].tv_usec);
